Re: Astec AA16990 PSU failure
I'm not sure what your purposes are at this point. If you want to see if it can deliver full rated power, be sure to notice that if all 3 outputs are at maximum current the output power will be 94W, well above the rated 86W.
With that noted, a 10A load on the 5V would, nominally, be 50W and the load resistance would be .5 ohm. Two 1 ohm, 50W resistors in parallel would be an easy way to do that.
