ESR meter upgrades
This is a sticky topic.
    Re: ESR meter upgrades
    Dear Vince in Options on AVRDUDESS you can select where is the AVRdude folder.
    They can be separate
    Just trying to help a bit in here
    Belen
      Thanks belen ive got both versions on my laptop now so will give them a try when i have fitted the headers to my esr tester boards im in no rush as my latest 2016 esr tester works fine and the old version im updating is just for a spare but need to replace the smd atmega328 ic first so then i can add a 16 mhz crystal and latest firmware so its a ongoing project just waiting on parts now (ic coming from china)
        AVRDUDESS is only a JAVA based GUI, you still need AVRdude installed for it to do anything - just so you know.
          Dear sjt
          Is there a way I can verify when it writes fuses or what might be wrong with my USBAPS's?
          Both of them seem to be broken
          I have shorte jumper 2 on both to program and unshorted trying to program an attiny
          Always getting this error from the Arduino IDE
          Code:
          avrdude: error: program enable: target doesn't answer. 1
          avrdude: initialization failed, rc=-1
               Double check connections and try again, or use -F to override
               this check.
            show what you typed to use the usbasp
              Dear sjt
              I'm trying to program an ATTINY85 with an Arduino IDE
              I did not type nothing I just configured the programmer in the IDE and tried to upload the sketch if its more easy whitn AVRDUDESS I really do not know how to upload an sketch into that or how can I know if now my fuses were wrote correctly?
              I used this configuration
              Thanks again
              Belen
                cant help - i know nothing about arduino other than the boards have a bootloader.
                  Ok regardless Arduino... with AVR dude can you do that? to be able to see if it's working?
                  I might try to program the original chip that came with the esr tester with the USBASP. But if yoiu want we can do it in another thread not to keep populating this one?
                  Sorry for my lates replies but I'm at work now ...
                  Belen
                    FUCK! - i just built a TFT tester kit for a guy, and the test socket is defective - the contacts dont open!!
                    has anybody else seen bad test sockets??
                      Yup, have the same problem with mine:
                      https://www.badcaps.net/forum/showpo...&postcount=479
                      Still waiting for a new socket to arrive from the eBay seller...
                        early version tester update
                        Sorry guys i have not updated this thread basically a mate wanted to borrow a esr tester as i didnt want to lend him my good one i leant him this one, yesterday when i went to collect it he has misslaid it! so he has gave me the cash to order another one so i can carry on with my project so this will be on hold for a few weeks.
                        this is the one i got him too order as it has a additional usb port already fitted im not sure what size atmega ic this has or even if it has a crystal fitted but i have the spares too upgrade along with a usbasp header.
                        http://www.ebay.co.uk/itm/2222029710...%3AMEBIDX%3AIT
                          why not just keep the money or buy another graphic model?
                            i can always another too what do you recomend?
                              i dont recomend any, you still have 2 of them - put that 10 into a frequency counter or other bit of usefull kit.
                              btw, i dont know what the hell the usb port is fitted for, there is no lithium battery or charge-circuit on that board - i suspect it either serves no function or is just a power input.
                                I think its a power input too as i didnt pay for it or order it i think he just went on what mine looked like, i was thinking about buying a frequency counter anyway as its always worth having one and cheap and another bit of equipment i have not got.
                                  well i just built this.
                                  this is for the COLOUR-TFT KIT. and will be known as "AY-AT" because it's printed on the pcb.
                                  this is tested btw.
                                  bmht, mr Hansson - you want to flash this.
                                    is that the tft you sent me the ebay link for? im just trying to find it again
                                      no, it's a kit from ebay with a red pcb.
                                      i dont recommend it - it's slow to update the screen, and i cant free enough memory to enable crystal testing!
                                        btw, how to fit a header in style!!
                                          thats a good place/mod for the header ive saw these kits on the eevblog thread i think too.
