ECS G31T-M - First Motherboard repair
    Re: ECS G31T-M - First Motherboard repair
    what CPU and RAM did you use?
    the P3x and G3x chipsets don't support CPUs with 533MHz (133MHz) FSB (some Pentium 4's and most P4 based Celeron D's) and they also won't work with DDR2 RAM slower than DDR2-667 / PC2-5300.
      E6750 and 2 X DDR2-800
        Did you solve it mate? I have the same motherboard but a little bit more complicated problem! when i plug the power supply and turn on it's switch the motherbord auto turn on, no power switch pressed and it does not boot or something! It had an intel q6600 quad on it and ddr2-800 kingstone when it was working! The caps looks fine i don't have a Capacitance meter is there a solution to this or some dirrection to troubleshoot this?
