I didn't want to bore everybody with a long post so below I listed the short of what I'm asking, but I also wanted to provide details in the long below. Thanks
Short:
I need help on identifying and replacing a capacitor and also finding if there is a way to test it in circuit.
I am looking at a capacitor that is a little gray box, on top of it is written:
MMKP82
683K630
And what does +5VMCU, CNT, PT, IS1 and IS2 mean?
Long:
I am trying to fix an LCD TV, it is an Element model ELDFW464, it comes on for a few moments and then the display goes off to blank and black I still have sound and the controls and remote work but the screen is blank and black, I've been told that this is symptoms of a bad back light inverter board, so I took the back cover off and only see two boards, the power board and the main logic board, I see NO other boards at all. Printed on the power board is: MEGMEET www.megmeet.com MIP988CF. On the main logic board is CV318H-D. You can see real good close up pictures of the front and back of the power board at shopjimmy.com
I back probed the connectors on the boards and all seemed correct (I think) except for on the power board when I got to the connector (CN4 top right corner) that goes to the back of the display panel, I don't know what I the reference designators mean and what readings I should be getting, the refdes are:
VBL+, VBL-, SGND, +5VMCU, CNT, PT, IS1 and IS2
it is an easy guess that VBL+ is "Voltage Back Light Positive" and VBL- is "Voltage Back Light Negative" and SGND is "Signal Ground" but what is +5VMCU, CNT, PT, IS1 and IS2?
After the TV display goes blank and black a green dianostic LED (DB9A) on the power board close to the connector CN4 blinks two times every four or five seconds, I have no idea what that code means. I then checked the voltage readings on the connector CN4 and I read no voltage on VBL+ or VBL-, I got 5.0 volts on +5VMCU and on CNT, on PT when I first turn the TV on it quickly goes up to 2.30 volts and then quickly goes down to 0 volts.
I took the power board off and started back tracing from the VBL+ and VBL-, on the VBL+ the first thing is a red capacitor (C142) the capacitor seems bad as I tested it in circuit with my ohm meter and it would not take a charge. Written on it is:
WFA 105K
450V
I plan on replacing it with this: Panasonic ECW-F2W105KA. The VBL- is connected to a capacitor (C140) that is a little gray box, on top of it is written:
MMKP82
683K630
I don't have a clue about this capacitor or what to replace it with. Searching on Google has not helped me at all. I don't know how to test it in circuit because it is connected to transformer ((T4) MIP988CF-T4 EC28-031 1139 01 REV.1.0) and inductor ((L11) MIP988CF-L11 EI28-014 1140 25 REV.1.10) What do the markings mean, what should I replace it with, do I have to take it out of circuit to test it? Any help???
Short:
MMKP82
683K630
Long:
WFA 105K
450V
MMKP82
683K630
