Dell Dimension 4700c Poly bliss
    This one was a dumpster find, was driving to the shop one day, and it was sitting on top of someone's trash cans... Couldn't help myself, I stopped and took it.
    It's a P4 3GHz, 800fsb, 2mb L2, 64-bit LGA775. Has 1gb RAM and a 200gb hdd. Instead of a floppy, it has a nifty little card reader in it...
    Mainboard caps were roasted panasonic FJ's (cpu filters). replaced all the 1800uF 6.3v CPU filters with 820uF 2.5v poly's. I also had to recap the power supply (full of cheapo teapos that had gone open).
    Cranking along now. Belonged to some girl named 'kelsey'......
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    Re: Dell Dimension 4700c Poly bliss
    Kelsey.
    There was this one girl named Kelsey when I was a freshman... rumor has it she hooked up with fifteen different guys that year .
      Topcat you're one lucky man to find that good of a system in the garbage. I wish people in my area threw away nice PCs!
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
        not bad... not bad at all...
        sigpic
        (Insert witty quote here)
          Hey Topcat, any chance that you'll put together a kit for this one? I have a dead GX520 and a dead 2700C. The 2700C has 3 vented caps that I've found. I've never done this before, so getting a count for a custom order might prove rather difficult for me. But I do enjoy getting my hands dirty and want to give this a go. I'm thinking of going the same route you went with the Poly's. Any advice?
            I've long since sold the system, and really don't remember what it took. When polymodding, you need to break out the volt meter and check the voltages on the lytics you wish to change to polies, as in many cases, the polies will have lower voltage ratings than the lytics.
            Team : 49813
            Join in!!
            Team Stats
