This arrived today, got it for $35. In tip top shape as opposed to the iiyama i got last week... Packed well.
Seller told me it's been messed with by someone, with no result. I haven't taken it apart fully yet, first wanted to see how it behaves. Plug it in and it lights up, shows an image for 30 seconds, then backlight turns off. If you turn it back on it comes off quicker and quicker, eventually reaching 2 seconds to black.
There is no flicker or dark areas, so i don't think it's the CCFLs. Could be the transformers or the switching transistors on the inverter. Edit: Opened it up and there's some pretty serious bodging going on. The original inverter section has been removed entirely, being replaced with a cheap inverter with cheap caps and cheap wiring. I'm going to test it with the lamps on the iiyama, and test the Acer with the inverter from the iiyama to isolate the problem.
