SuitCase PC. :/
    Re: SuitCase PC. :/
    Originally posted by c_hegge
    Phaihn, How are you going with your suitcase so far? I've nearly got mine done. I just need some RAM and a small enough monitor to fit in the top (about 15" square for 16" Widescreen)
    Gave up i got bored and i decided i didnt like the size of my suitcase so i threw it out ill try again some other time but i want to try a mini itx board instead and i am moveing back to edmonton alberta soon so i needed to make space.
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
      Re: SuitCase PC. :/
      Edmonton a pretty small town is it?
      Can't fit another PC in?
      I just got one of these.
      http://www.avalue.com.tw/products/EBM-945GME.cfm
      C2D w/PCI-e and only 8" x 5.75". - About the footprint of a CD Rom drive.
      Ad pic shows KZG but it came with all Sanyo.
      Not sure what I'm gonna do with it yet.
      Still waiting on a T2400 CPU & RAM to get here.
      They only had one. *sniff*
      I could fit about 3 of these in a standard ATX case.
      Mann-Made Global Warming.
      - Dr Seuss
        Re: SuitCase PC. :/
        Not really Edmontons more of a metro but i wasnt liking how the Thing was turning out anyway ill try to get back at it when i find a difrnt case.
        My Computer.
          Re: SuitCase PC. :/
          Here's how I'm giong with my Briefcase PC. The components I'll be using:
          Motherboard: Gigabyte GA-M61PME-S2P
          CPU: Athlon 64 X2 3200+
          RAM: Don't have any DDR2 yet.
          HDD: 20GB Seagate U series 5 (for now)
          Optical Drive: Lite-On CD Burner (for now)
          PSU: 450W Codegen
          Monitor: Don't have one that fits in the top yet. (needs to be 15" square or 16" widescreen). All I have is a 17".
            Re: SuitCase PC. :/
            Nice, but why did you use that crappy PSU? (or has it been modded and recapped?)
              Re: SuitCase PC. :/
              The only mod I did to that PSU was adding some extra connectors. Other than that it is as it left the factory. I used it for 3 reasons:
              1. They're not that bad (ie. not as bad as Deer or that 250W Worstec model in some Evilmachines).
              2. It doesn't make a high pitched squeal under load like all my re-capped Antec Smartpowers do.
              3. Smartpowers are slightly longer and don't fit.
                Re: SuitCase PC. :/
                Originally posted by Phaihn
                Heres something i am working on.
                Any advice?
                I am trying to figure out how to organize everything.
                Just stick it in a standard atx tower :P You'll need some cooling definitely for that
                  Re: SuitCase PC. :/
                  then it wouldnt be mobile
                  My Computer.
                    Re: SuitCase PC. :/
                    1. I would argue that most deer's would beat out a codegen no problem. Codegen is known for 'ploding even under a light load. Where as most deer do fine at 200-250W loads. some are even overbuilt true 600W units
                    2. Bestec's aren't bad at all after a recap. They actually run their ratings as well as having full protection circuits, transient filters, medium quality fans, thick gauge wiring, etc...
                      Re: SuitCase PC. :/
                      370, I've NEVER seen a codegen go bang or take a board out (unless it gets hit by lightning). I opened the case on this one and it looks better than many of the gutless wonders I see on this site. I can post a pic of the inside if you like.
                        Re: SuitCase PC. :/
                        please do post pics.
                        all the codegen units i have seen here were total gutless junk.
                          Re: SuitCase PC. :/
                          Got some pics now. Here they are.
                            Re: SuitCase PC. :/
                            NOOOO!!!
                            i see 4 diodes in place of a bridge rectifier. not even close to ok.
                            not enough caps on the secondary.
                            the wire is too thin.
                            sorry, but your PSU is a POS.
                            sigpic
                            (Insert witty quote here)
                              Re: SuitCase PC. :/
                              Ugh, looks too much like a leadman. You couldn't even put a bridge rectifier in there with how those diodes are arranged.
                              I'd say it's 200W at best. But I would need to see what is on the primary and secondary heatsink.
                              I'm going to assume it is like most cheapies and has two 13007 knock-off's which the good ones from fairchild are really only good for a 300W unit.
                              Secondary chokes have some thin wiring, as well as being small. All the secondary rectifiers are to-220 which leads me to believe they are probalby all 20A rectifiers, but most of the time they cheap out for the 12v rail and use a 12A or a 16A unit there. Thought it looks like there are two rectifiers on the 12v rail. Still, that dosen't mean something else wouldn't go poof in it, especially since the primary transformer is microscopic.
                                Re: SuitCase PC. :/
                                Looks worse than Deer/Allied, but not horrible like Leadman/Sun Pro (probably closer to L&C, but with better output filtering).
                                The input rectifying diodes are really are small, but heatsinks seem okay. At least there is no two-diode treatment for a 12v "schottky" rectifier . That's a big no-no for any system.
                                Might be okay for the system you're using (I'm not too keen about that idea, though).
                                And what the Hec are those caps ?
                                  Re: SuitCase PC. :/
                                  So it's a junk PSU, but it's the only PSU I have that fits and doesn't make a high-pitched squeal under load. I'm also not looking to spend more than I really have to on this project, so I'll use it for now. I might put a better one in it later.
                                    Re: SuitCase PC. :/
                                    I don't know, even that leadman looks pretty good compared to it.
                                      Re: SuitCase PC. :/
                                      Yes, but most newer Leadman/Sun Pro units I've seen here seem much worse than this Codegen.
                                      c_hegge: If the voltages are reasonable and stable, PSU runs cool, and if this whole system will be used only once in a while for light duty stuff, then the Codegen will probably be okay (at least until the caps go bad).
                                        Re: SuitCase PC. :/
                                        All conditions there are true. The voltages are stable, it runs cool and it won't be used that often and when it does get used, it will probably just be for basic stuff like internet, word processing, etc. It will probably be running linux (either ubuntu or mandriva).
                                          Re: SuitCase PC. :/
                                          To be fair to Codegen...before I knew about badcaps. I have ran a crappy Codegen in a Socket A system for about 3-4 years without problems.
                                          It even works till today! However I do not use it anymore and it has not been turned on in close to 2 years.
