Diode or resistor
    Diode or resistor
    Quick question, I'm obviously a noob, what's the name of this?
    http://imgur.com/l8sJYBX
    Re: Diode or resistor
    Resistor
      For clues look at the location number..
      Rxxx = Resistor
      Dxxx = Diode
      Some are not so obvious for eg...
      Lxxx = Inductor
      etc
        Can someone tell me the correct number i should see on the multimeter when reading these resistors?
        http://imgur.com/3Ohggl1
        http://imgur.com/ZeFrA5s
        http://imgur.com/PUH93t0
        http://imgur.com/Pl2Y9Ew
        http://imgur.com/d0YE2Xw
          see this
          Code:
          [URL="http://www.digikey.com/en/resources/conversion-calculators/conversion-calculator-resistor-color-code-4-band"]http://www.digikey.com/en/resources/conversion-calculators/conversion-calculator-resistor-color-code-4-band[/URL]
              As long as you don't go OL you can figure it out.
              Set to whatever setting and check... if you get OL go up... if you get 0.002 go down etc
