So i had bad caps on my monitor. replaced them with new one's but it isn't working. I have picture but backlight isn't working, not for even a sec or two.
how to test pico fuse? is it same as other fuses? I removed it from board and tried to test it. when I put my multimeter on diode mode it isn't showing anything, same in 200 ohm range. but if I solder it where it should be on diode mode it shows some reading, in 200 ohm range it isn't showing anything...is that fuse ok or not ??
thank you, and sorry for my bad english
