Thinking about buying one YIHUA 853AA 2in1
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
All of the mosfet that are taken out by bad capsTags: None
Re: Thinking about buying one YIHUA 853AA 2in1
Alright thanks for the info
Would this be a better choice
Desoldering Station with 1600W Preheating Oven & 1500W PCB Preheating Plate
http://www.ebay.com/itm/Desoldering-...QAAOSwkShY8vzZLast edited by sam_sam_sam; 06-03-2017, 01:47 PM.9 PC LCD Monitor
1 Dell Mother Board
I know that but is the size big enough9 PC LCD Monitor
1 Dell Mother Board
For TV boards and controller boards
Can put board where you need to remove whatever chip you need to do
Or maybe I do not understand how to use one
I already have a temperature controlled / air flow control hot air gun with a stand to hold itLast edited by sam_sam_sam; 06-03-2017, 06:37 PM.9 PC LCD Monitor
1 Dell Mother Board
Originally posted by stj View Postthe idea is not to heat under the chip, but to heat most or preferably the whole board.
if you only heat one area it can warp.
You CAN heat under the chip, but it is also preferable that you heat the rest of the board to a certain level as well, so as to avoid warping.
That's why industrial reflow machines are actually 3-zone: a general bottom-side board heater that heats the whole board (but not to a very high temperature), a bottom heater under the chip, and a top heater above the chip.
Or if you are crafty, you can just use a bottom heater under the chip, but then you need to extend the time the board is heated from the bottom so that the whole board heats up eventually from the bottom heater. FWIW, I do that on a gas stove, and I've done enough successfully reflows now to say that it actually works better than the cheap Chinese garbage IR stations that don't heat evenly worth a squat.
Thanks for the info9 PC LCD Monitor
1 Dell Mother Board
