Hello everyone! I just got what I hope is a good deal on a 2 year old 50" LG plasma. Using the training manual for this model I have determined the problem is in the power board. (I could not upload the training manual due to its' size.)
The problem with the power board is that it will not stay on. When power is applied it will click on but will shut down about two seconds later, with a load or without one. It shuts down faster when the light bulb load tester I made is attached to it. The manual called for two 100W bulbs in series (200W load), I used two 60W in parallel that are in series with a 90W bulb (210W load). In the brief time it is on, all the necessary voltages are there and they seem to be at the correct level. The training manual says that with nothing but the AC power and the load tester connected (no main board) the power board should come up and stay on. I even tried forcing it on following the manual's instructions using jumpers and resistors and the results are the same, click on, click off.
From what I have read it seems that IC701 is supposed to control all the functions and it seems to me that some kind of circuit protection is kicking in and shutting it down. I cannot find a datasheet for this IC which is a F4316MSF17, the only datasheet I could find was for another IC on the board, a L6599AD chip and I have attached it to my post. I figured if you could find out what could cause the protective circuitry to trip then it would narrow down where to look for the problem. I am hoping someone on the forum can point me in the correct direction to find the problem with this board as my searching has not turned up anything useful. I would like to post the training manual but the best I can do is to provide a link to the site where I got it.
I will be very appreciative of any help you could provide.
Thanks,
Lloyd
Thanks,
Lloyd
