My girlfriend's sister gave me her TV to look at because it would not turn on. It has a push button with a red led standby light in the bottom center of the TV that is continuously lit when the power cord is plugged in. I have a similar TV in my bedroom, I thought it was the same and was hoping it was a simple capacitor swap job like mine was but it turns out the model numbers are different.
The TV will not boot up, usually when you press the center button or remote, the standby light will begin to blink after a few seconds and the TV boots on with a chime. When you press the button or use the remote, it stays in standby mode. GF's sister turned off the computer connected to it (HDMI) and the TV went into standby mode, and the red led light was blinking. The next morning the standby light was steady but the TV wouldn't turn on.
I removed the Power board, BN44-00192A model MK32P3 and looked it over and only found one questionable cap, a 10V 1000uF (Samwha), none of the capacitors looked bulged though, it just looked like plastic casing was peeling away. After I removed it, I hooked it up to my ESR Micro v4.0s and got a 0.00 Ohm and 965uF reading.
I decided to do the shotgun capacitor swap with caps from a local distributor. It still will not boot up.
Anyone familiar with this model? I did a search on this board and an ebay seller says to replace this big ol' aluminum 35mm 450WV 150uF cap if the indicator light is red but it wont boot up.
No luck, TV still will not boot up.
