Hello all,
got this monitor to fix.
The symptom- when turned on, works for a minute or so but then starts to flicker slowly. sometimes the backlight just turns off momentarily and back on, but sometimes it's off for longer - and in that case the monitor just turns off and back on after couple of seconds (the whole monitor restarts) and i hear some sqeal for SMPS tranformer area.
I got 5v steady. But as for the 15v line which i suspect - with main board disconnected it measures ~17.5-18v. when monitor is working fine - this line is 14.5v (good) but while the monitor restarts this climbs up to 18-19v.
i read some posts suspecting startup cap, does it fit to symptoms ?
would appreciate any thoughts
