Hi, this plasma TV flashes the front red LED 6 times at plug-in and then nothing (it does not repeat) however the LED does flicker in response to the remote but the set never powers up, no sound or picture. The relay clicks in on the first flash and on the second flash the screen briefly flashes random white lines.
The green LED on the control board flashes 5 seconds on & 2 off and repeats which seems to indicate X or Y-main failure (or both) from what I have read in other threads but the symptom is exactly the same if I disconnect X-main or both (except the screen does not flash). Shouldn't the unit power up with sound but no picture?
VA,VS & Vscan are all spot on (58,207,-185 as marked on panel) as screen flashes but then quickly drift down to <1v as control board sets VS_ON back to 0v
I have removed both X-main and Y-main to check and there are no shorts on either (VA to GND, VS to GND or any FETs, SMD or through -hole)
If I disconnect main board and short PS_ON to ground and jump pin 3&4 on control board for test pattern, no result, just 5-2 flash on control board as before.
If only the main board is connected, it still flashes the front red LED 6 times.
If I got sound but no picture with X & Y-main disconnected I would look at replacing them but should I be considering the control board first?
Any help appreciated, thanks.
