Hi guys I was replacing the start up caps on this board and I pulled the copper trace on the 1uf @50 volts. The other two 22uf @50 volts were ok I know some of you have repaired broken traces but this is so small I can't see where the circuit leads. My question is how are these three caps connected in the circuit? Can I use a jumper to the leg with the broken trace?
Broken Trace
Re: Broken Trace
Originally posted by davg View PostHi guys I was replacing the start up caps on this board and I pulled the copper trace on the 1uf @50 volts. The other two 22uf @50 volts were ok I know some of you have repaired broken traces but this is so small I can't see where the circuit leads. My question is how are these three caps connected in the circuit? Can I use a jumper to the leg with the broken trace?
-BenMuh-soggy-knee
Re: Broken Trace
Thanks guys I did as ben7 suggested as shown in the photo. This board was not powering up no led but I did have 5volt and 12 volt to the logic connector and 169 volts on the large cap.I replaced these three caps because they were the only ones that were not replaced and now I don't have any voltage to the logic connector but still have 169 volts on the large cap. Did I loose the voltage because of the broken trace?Last edited by davg; 09-18-2012, 07:32 PM.
Re: Broken Trace
looking at your pictures that leg of that copy does not go to that resister if you get a strong light and look at a cleaned up pcb you should be able to see where it should go witch I think is to D106 looking at D106 from the top of the board it looks like D106 may be faulty and also I would be checking most of the silicon around that area and check all the caps around there.
popeye
Re: Broken Trace
Originally posted by popeye View Postlooking at your pictures that leg of that copy does not go to that resister if you get a strong light and look at a cleaned up pcb you should be able to see where it should go witch I think is to D106 looking at D106 from the top of the board it looks like D106 may be faulty and also I would be checking most of the silicon around that area and check all the caps around there.
popeye
I wasn't sure what pad was broken, b/c it wasn't marked.Muh-soggy-knee
Re: Broken Trace
Originally posted by popeye View Postif you get a strong light and look at a cleaned up pcb you should be able to see where it should go--- begin sig file ---
--- end sig file ---
Re: Broken Trace
Originally posted by retiredcaps View PostI hold a board up to the sun so it shines behind the board and then take a photo of it. It works great for some boards.
Re: Broken Trace
I look at the picture, since that leg of the cap is negative, then it should go to ground of the primary side, see the picture.
What is the P/N of that IC, it looks like pin 2? is connected to ground also. need IC spec to find out. It also looks like there is a connected trace to the right of the PAD also.Never stop learning
Re: Broken Trace
Originally posted by budm View PostI look at the picture, since that leg of the cap is negative, then it should go to ground of the primary side, see the picture.
Re: Broken Trace
So right now the negative leg of that cap and the trace that I indicate are new all connected to the ground trace?Never stop learning
Re: Broken Trace
Originally posted by budm View PostSo right now the negative leg of that cap and the trace that I indicate are new all connected to the ground trace?
Re: Broken Trace
"Can I run a jumper to one of thes negative points and get the same results"
Do you mean that you have already jump the negative leg of the cap and the trace to the ground trace as shown in my picture and it still does not work?
I will look tomorrow to see if I have the same board laying around in my part bins.Never stop learning
Re: Broken Trace
Originally posted by budm View Post"Can I run a jumper to one of thes negative points and get the same results"
Re: Broken Trace
Can I see that section of the trace that I have readlined to verify, the picture you posted was not clear enough. I still have to look up the spec of the IC. You can connect the negative leg of the cap, but not the trace until I can see the picture clearly, but I believe that broken trace is the ground trace.
So far no luck with that IC EA530 P/N search.
By the way, what is the make and model of this monitor?Last edited by budm; 10-05-2012, 09:58 AM.Never stop learning
