Msi 865gm2
    Msi 865gm2
    Hi, have and 865GM2 (MS-6743G) motherboard from an Acer Acerpower F1 PC, which does not post anymore. Bios has not been flashed. When applying power the CPU fan starts up straight away. have already tried another PSU. Is this board salvageable? Any known bad caps on this board? It has Rubycon electrolytic caps. Any help or advice appreciated!
    Re: Msi 865gm2
    Pics?
    If the caps are entirely rubycon, then they are probably OK. I had a similar board over a year ago. IIRC, it had a mixture of rubycon and G-Luxon.
      Re: Msi 865gm2
      also, maybe try resetting the bios back to factory standards to see if that might do it. if there is something a little wrong with the speeds or voltages, it can do it. Resetting the bios will usually bring it back to either basic speeds or lower to make sure there the system will boot.
        Re: Msi 865gm2
        Tried that with no luck...
