Hi could anyone tell me how to fix this please.
Please Help!!
Re: Please Help!!
What kind of components that fit into those holes? If they are through hole components, I would use 24AWG solid bare wire and wrap the wire aorund the component's legs then solder, then I would apply epoxy glue on top of it.Never stop learning
Re: Please Help!!
Originally posted by budm View PostWhat kind of components that fit into those holes? If they are through hole components, I would use 24AWG solid bare wire and wrap the wire aorund the component's legs then solder, then I would apply epoxy glue on top of it.
The thing is most of the track as come off as you can see in picture. i gave it to a mate who said he could fix it and ended up coming back looking like that.
he burnt the tracks with the soldering iron and took the track off. i just can't see where it joins as im not good at this sort of thing.
http://www.ebay.com/itm/2pcs-MITSUBI...05%26rk%3D1%26Last edited by StevieG; 08-15-2012, 08:48 AM.
Re: Please Help!!
OK, you trying to figure out how all the legs of the components are hooked up to each other and the orientation of the transistor due to the old copper traces are gone.
Can I see the top side of the board then I may be able to figure out which hole is the the Gate of the transistor.Never stop learning
Re: Please Help!!
Originally posted by budm View PostOK, you trying to figure out how all the legs of the components are hooked up to each other and the orientation of the transistor due to the old copper traces are gone.
Re: Please Help!!
What is the board part number and what is it offPlease upload pictures using attachment function when ask for help on the repair
Re: Please Help!!
OK, This MOSFET is used for the RF Power amp putput stage, Pin 2 of this MOSFET is SOURCE pin instead of DRAIN pin like other MOSFET, but since it is made for RF circuits which need to have minimum stray capacitance in the construction of the silicone die and the internal lead connection, they make pin 2 (middle pin) as a source pin.
Please se picture and spec sheet on how to put this MOSFET in place.Never stop learning
Re: Please Help!!
Originally posted by budm View PostOK, This MOSFET is used for the RF Power amp putput stage, Pin 2 of this MOSFET is SOURCE pin instead of DRAIN pin like other MOSFET, but since it is made for RF circuits which need to have minimum stray capacitance in the construction of the silicone die and the internal lead connection, they make pin 2 (middle pin) as a source pin.
Steve
Re: Please Help!!
Just make to see the spec sheet on the pin out. Good luck.Never stop learning
Re: Please Help!!
Do you get the power before? Can I see the whole picture of the board so I can see where the power is applied and the way you have install the MOSFET?Never stop learning
Re: Please Help!!
Originally posted by budm View PostDo you get the power before? Can I see the whole picture of the board so I can see where the power is applied and the way you have install the MOSFET?
heres a couple of pictures of the board.
Re: Please Help!!
Might seem a silly question but where does the power feed into the board and what voltage is it?Please upload pictures using attachment function when ask for help on the repair
Re: Please Help!!
That power cable? (the gray cable on the bottom right of the board as shown in pic1, see if there is shortes circuits there, see if you have any voltage on that blue electrolytic by that gray cable.
I see a DC input jack by the gray cable also.Never stop learning
Re: Please Help!!
Originally posted by budm View PostThat power cable? (the gray cable on the bottom right of the board as shown in pic1, see if there is shortes circuits there, see if you have any voltage on that blue electrolytic by that gray cable.
Re: Please Help!!
You need the meter for sure, do not leave the power connected since you may have short circuits somewhere or you may have bad power source, power switch, etc.Never stop learning
Re: Please Help!!
Originally posted by budm View PostYou need the meter for sure, do not leave the power connected since you may have short circuits somewhere or you may have bad power source, power switch, etc.
