Lite-ON made Dell SX280 PSU
    Just fixed/modded one of these. Filled with OST and L-Tec caps. No bulging but a lot of mediocre (in case of OST) and bad readings on some of the Ltec caps.
    A weird mix of Nichicon PW, HD, HM and UCC KZE was used to recap it. Mouser's stock was funny this time.
    The main switching MOSFET isnt very good and has a drain-source on resistance of almost two ohms. Swapping this for something more modern results in a cooler running supply. You can FEEL the difference! 2SK2654 was swapped for a Fairchild FQA8N100C.
    Fan was good, unlike the other version of the supply I'm used to (Hipro IIRC). The Lite-ON uses a 60x15mm fan, the other takes a skinny 60x10mm.
    The mobo is weird on this one...all Rubycon MCZ and Panasonic FL except for three Nichicon HNs. Why didn't they go all the way?
    Re: Lite-ON made Dell SX280 PSU
    Whoops...its a GX280! My bad.....
      Had me going with the thread title....was thinking to myself that I've never seen a bad DA-2 PSU (sx280 external, also used on the gx620usff). Made more sense after seeing the gx280 correction.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
