Need help identifying capacitor values
    A friend of mine managed to knock off 2 surface mount capacitors from his EVGA GTX 670 graphics card. I offered to look at it for him, since I assumed the parts would be cheap enough to make it worth fixing. Now I am having trouble identifying the values for the capacitors. From looking at other pictures of the PCB online I have found that the caps are identical to some others on the board, so I took a picture of one of them in hopes someone here could help me identify it.
    (The two large black ones)
    I tried resolving the code on it and looked up 47pF caps, but I couldn't come up with anything in this size.
    Thanks for any help!
    Re: Need help identifying capacitor values
    470uf .. unsure of voltage
      470uf POLYMER ALUMINUM SOLID ELECTROLYTIC. The small `d' is 2 volt This pdf might not be the correct series
