I-Inc IF281D Display Problem
    Re: I-Inc IF281D Display Problem
    I think you need to get the house wiring checked out not the monitor
      Bad cable? I had a HDMI cable to when the fridge kicked in blanked off..
      Also had a TV that used to switch into standby when the Mrs hardbooted her PC... Turned out there was a short on the HDMI cable allowing interference... Figured it was a short as when I touched the HDMI cable I got zapped LOL
        Well once again I found a solution over here! NewtoThis, thank you my friend, it was my cheap HDMI cable, I connected the old DVI cable instead and all is OK. I bought a cheap HDMI on amazon, something like 3$... The cable that came with the monitor is HDMI/DVI now that I have installed it, no more problems. Selldoor, electrical variation in a house is business as usual, besides that, all my 6 other LCD displays were ok Thanks anyway.
          Yeah there is very little shielding in cheap cables so the compressor on a fridge can disrupt the signals. As soon as you mentioned the fridge I knew it was probably that
