password backdoors?
    password backdoors?
    Am going to install Ubuntu 5,04 (Hoary Hedgehog) on 2x HP BrioPC with mendocino 433 and PhoenixBIOS and 2x whitebox system with tualeron 1700 (?) and AwardBIOS. Does anyone know of any password backdoors for the BIOSes as they are all p/w protected and none of them have CD as first boot device.
    The great capacitor showdown!
    Re: password backdoors?
    You have to clear the CMOS (or password - brand machines usually have separate jumper for that).
      So I can unplug the machines, remove cmos battery and leave to sit over weekend.
        Pull the battery out for a couple hours, that will discharge it, and erase any passwords. Of course you'll have to reset all the BIOS parameters also.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
          Did that on one whitebox (asus p4b533 so Willamette Celeron) and now boots up without a p/w.
            what happened about the linux install.
              ubuntu 5.04 installed perfectly on the p4b533-vm. the Brio must have a capacitor backup for the memory as it still prompted a password after battery being disconnected overnight.
                http://www.uktsupport.co.uk/reference/biosp.htm
                did you try some backdoor passwords...........i cant believe they have them....
                  Get a manual and use "clear password" jumper or DIP switch.
                    Will try to get manual for Trigem Cognac board as that's what is in the Brio PCs.
                      this u want?
                        thanks Will, I looked but no password jumper.
                          Try the clear CMOS jumper - the usage is described here http://h10025.www1.hp.com/ewfrf/wc/d...cname=bph07169 (you need to turn the power on with the jumper in the "clear" position).
