dell sx270 chipset heatsing problem
    Hi, i recvied dell sx270 dead, i open cover found two cap. bulging, i replaced
    new cap. which was 1800/16v.and 2200/6.3. now power on and disply is ok, but another problem showing WARING ,alert chipset heat sink not detected . I CHECKED ALL COVER ITS OK, i DONT' KNOW WHAT IS PROBLE. please help me? thanks advance,
    Re: dell sx270 chipset heatsing problem
    the chipset heatsink on these models is held on by two metal loops, which have a trigger if one pops off to do this. I took a loop off one a dead MB (they're all essentially the same part) and soldered it on, problem fixed. the system did have bad caps too and I replaced them while I had the MB out for the hell of it, but the guy did not complain about stability problems
    the thermal paste dell uses becomes an adhesive over time and the northbridge heatsink on this box did not move even after the clip broke (popped off due to crap solder)
      Yeah I've seen this multiple times - the little metal clip breaks off on one or both sides, and it gives a thermal error upon bootup.
      Easy enough to fix either get a new heatsink or fix the clip.
        in the worst case one could fashion a new clip out of a paperclip... just bend, cut, and sand (to get it down to bare steel, which wicks solder).
        also replace the thermal compound, as the bubblegum pink crap is just like gum and just as useful...
        sigpic
        (Insert witty quote here)
          i've tried this before and have had varying results, if you don't make the paperclip the perfect size, the heatsink will lean over and lose contact on half of it. salvage one off a bad mb, they're like ALL the same size, no idea why
            If you heat it, it will likely become softer.
            I was working on an old Shuttle PC last week that had that kind of thermal paste on the NB. Took the heatgun and blasted the NB heatsink for a few seconds just to get it hot enough to burn fingers. After this, the thermal paste became much softer and I was able to remove the NB heatsink.
              http://search.digikey.com/us/en/prod...400-ND/1216404
                yes it will soften when you heat it, BUT...if you heat and cool it, over and over, a few hundred times a year, it chemically changes and becomes adhesive. I think some of the components of the paste melt, form bonds with other components, and melt even more, cool, and do the same thing over and over
