sony kdl-46S4100 dark, no sound, inverter?
    I have a sony kdl-46S4100 that one day went dark,
    no sound,
    powers on by the remote,
    has a click at power on,
    power light glows steady,
    no backlight that I can see
    no heat detected anywhere
    remote fails to do anything after power on
    no sound, no smell
    Ive been swapping parts from ebay trying one different board at a time
    power supply board - no change
    main board - no change
    I have a salvaged tcon board and inverter board that i have not tried yet.
    Anyone have a beginners troubleshoot algorithm that I can do with a multimeter? Sorry in advance, I'm trying to learn this as I go.
    Re: sony kdl-46S4100 dark, no sound, inverter?
    no sound,
    no sound, no smell
    Blink Code?
      No blinks - this model does not do that
        You are correct. It does not do that.
          Faulty panel or t-con.
          Could be either with this panel.
          check for 12vdc or so at t-con board fuse (very small near plug).
          Grey panel (some backlight trying to get through) could mean no power to t-con.
          Run through inputs with dvd plyer hooked up and listen for audio.
          Just a few ideas for you.
            Solved!
            Thanks to cadiman for the tip - I swapped out the salvaged t-con board and it started working. I am still looking for the fuse in case this one fails too.
            My process was:
            take the back off and look for any bad caps anywhere on the PS or main board - dead end
            research web for known issues -couldnt find any exactly like mine - most had sound or some other first symptom
            swap out power supply with a ps from ebay - dead end
            found another guy on ebay selling the guts of a tv like mine with cracked screen
            swap out main board - dead end
            put all oriiginal parts back in between attempts
            buy a correct screwdriver that loosens really small phillips screws without stripping
            remove tcon board
            jerked out the ribbon cable from the board and tv - then found there was a little tab that popped up that pinched down the cable - luckily I didnt destroy the ribbon
            test
            shout up the stairs that I fixed my tv
            Thanks for the tip and the forum
              You would have better luck using a microscope than any type of eyeglasses to find the fuse on the t-con. should be next to the input plug. The board will be marked F with a number after it like (F101). F for fuse. R for resister , D for diode etc.
              If the fuse is blown on the t-con do not jump it with solder.
              Glad we could help you!
                I also have a sony kdl 46s4100 and have the same exact problems that Houston1381 had. So i tried swapping the t-con board with a salvaged one but nothing happen. I was wondering if someone can please help me.
