it is still talking to computer but not charging so I will patch that trace tomorrow and see what it does not even sure when it burnt as it was charging
cable has non standard pinout(thanks apc!)
iirc there is still a site ups club that has pinout and schematics of these older units.
supported under windows and linux natively.
these i add a fan to that only runs in inverter mode.
so now you have a charger,monitor,and a working ups limited only by the battery you connect.
first on the 350 I found the problem with the charging circuit apparently the TL780-15 blew out as it is only outputting 1.5volts.
now on the backups 400 do you happen to know what the charger can output as I have no interest in the inverter portion of the unit only the 12vdc side but I had to plow the charging circuit the first time I hook it up as I will be pulling roughly 3amps eventually 5amps,
If it uses one 12V battery then more likely to be the same setup as the 350, around 1~1.5A for charging circuit, you can look for the voltage regulator on the board around the transformer.
ok would it be possible to use something along the lines of what you posted earlier that but to use a relay to use an external charger instead of the built-in charger or would this cause the ups to be unable to detect the battery? the reason for this being I don't want to kill the builtin charger pulling to much current or my deep cycles by not charging them with enough current.
The UPS batteries monitoring circuit that talks to the computer is connected to the terminals of the batteries, so if you connected the external charger to it, you will have to make sure that the external charger will not force feed the Voltage/current into the internal charger and cause damages. What does it show on the PC right now on the 350 when the power switch on the UPS is not on and the batteries is not connected?
It should communicate with the computer even when the power switch is off (if that is the way APC works, I am not sure), the charger is also always on regardless of the power switch is on or off. The blown 780-15 may also used for running the monitoring circuit beside running the charger.
The monitoring works the same way as what you are trying to do, when the power is present it runs off the power supply and when AC is not present it runs off the batteries so it can keep the communication going with the PC.
