I have a NS-50P650A11 that clicks 2 timeand goes back to standby mode after you press the power button. I have replaced the logic board. I have removed the connector on the y main board to the psu and still the same. I also removed the connector from the x main board from the y main board still the same. Also I have disconnected both connectors on both boards and still the same. Do I have a bad psu boards?
NS-50P650A11 clicks 2 times
Re: NS-50P650A11 clicks 2 times
Update:
Plugged everything and left the logic board disconnected. Pressed the power button, psu clicked on voltage climbs up a little about 5V on the VS and less than .1V on the VA for about 10 seconds, then psu clicks off. Mind you that I've replaced the logic board already. Do you think I got a bad logic board?
