As the title indicates I have a 2493hm,
before I post pictures i just wanted to bounce this issue off some of you guys. I'll mention that I've been unable to find anyone with the same issue as this one.
What happens is that the monitor will work just fine for about 15 minutes then the image will flash and then it will start to cycle through the inputs (digital, analog, hdmi) it will stop briefly(2 minutes) on the HDMI show the proper image, complain about the resolution then continue the cycle.
I thought it was something screwy with the power supply so I went to digikey and replaced all the caps excepting the big one with Panasonic's with slightly higher voltages.
where do I go from here oh gurus of capacitors!
