I have an IR6000 and i installed a 12v fan to it, it already has a 12v fan for the top heater so i simply cut the 2 wires and bridged them for the new fan to use for the bottom heater with the existing switch
The fan works just fine, however sometimes when i flip the switch the machine resets ie; it turns on and then off
If i leave the switch flipped on and turn the machine on the machine kind of pulses on and off until i turn the flip the fan switch off
Sometimes turning the 12v led off and back on makes it work, the 12v led is not on the same switch but its on the same enclosed power supply
The other components such as heaters and controllers are directly on 220v not going through the power supply
