Hi.
We have a light in the dining room. There's currently two switches that control the light. One is by the outside door, that brings you into the room. The other is by the stairs that lead upstairs. Many times, we'll be in the kitchen and want to turn the light on (we come in through the back of the house a lot because we have off-street parking back there).
I've wired three-way switches before, but for this, I think I'm going to need to wire what's called a four-way switch. I've done a little bit of research on them and need to do a good bit more before I attempt the project, but out of curiosity, has anyone got any experience with these four-way switches?
I'm curious as to what would be the best way to hook this up. It'd be on the same wall with the switch that goes to the stair case. This is on the 1st floor and I'll probably have to do something in the basement I figure. Maybe find where the wires come up from the panel box and add a junction there.
Once I familiarize myself with how they work and how to wire one up, I was thinking I could maybe just tie into the junction box and run some new wires for the four way. It's been a very long time since I wired a three-way switch up and I should probably refamiliarize myself with that as well. If I remember correctly, with the three ways, the white (neutral) goes directly to the light, the black (hot) goes to the first switch. Then I think the red and another white go to the second switch, but I think they both act as hot....the second switch gets the red and white connected from the first switch and it has a black (hot) that goes to the light.
It's been a long time since I wired one though so I might be wrong. I'll google it tomorrow. Any suggestions or tips on the four-way?
