ESR meter upgrades
This is a sticky topic.
    Re: ESR meter upgrades
    the firmware in USBasp is newer than AVRdude, there is no problem - the timing is simply automatic.
    so you dont need to set it.
    as for them not working:
    try:
    avrdude -c USBasp -P usb -p m8
    it should say
    avrdude: warning: cannot set sck period. please check for usbasp firmware update.
    avrdude: error: program enable: target doesn't answer. 1
    avrdude: initialization failed, rc=-1
    Double check connections and try again, or use -F to override
    this check.
    avrdude done. Thank you.
      Dear sjt
      I'm telling you since I updated the firmware my computer refuses to see any of them. I can see them in the device manager but otherwise they are not recognized.
      Code:
      C:\ASP>avrdude -c USBasp -P usb -p m8
      avrdude: error: programm enable: target doesn't answer. 1
           this check.
      Belen
        updated what firmware?
          The USBAP one as in this page
          http://www.rogerclark.net/updating-f...ght-from-ebay/
          Now my computer doesn't seem to see it
            well firstly assholes like roger clark shouldnt be allowed online.
            the firmware in the chinese programmers is NEWER and better than the official 2011 asp firmware.
            http://www.fischl.de/usbasp/
            so all you did is DOWNGRADE it.
            so now you need to download this firmware.
            and use it with:
            avrdude -c USBasp -P usb -p m8 -U flash:w:usbasp-2011.hex \-U lfuse:w:0xef:m \-U hfuse:w:0xc9:m
            or
            avrdude -C ../etc/avrdude.conf -c avrisp -P COM6 -b 19200 -p m8 -U flash:w:usbasp-2011.hex \-U lfuse:w:0xef:m \-U hfuse:w:0xc9:m
            this will get them running, but they will never have the latest firmware because it's not public - thank the asshole Roger Clark for that!
              bmht thanks for the update is your esr tester ok now? or are you still having issues? try what stj says regarding the firmware on the usbasp it should get them working again
                stj this is the video tom66 linked for me in eevblog so i guess all i have too do is use the headers i fit to the esr testers and use them rather than the breadboard method
                https://www.youtube.com/watch?v=J_LYhHUS26c
                  Oooops I did not knew he was an @@sss
                  Since I was having clock issues with my USBASP I read yesterday that is was due to firmware issues.
                  Sorry I dod not answered before I was doing grocery shopping and visiting my parents now I'm back
                  Frankly I think yesterday although it did not seem like I learned a lot.
                  Vince YES!!!! my tester is up and running finally thanks to you and the help of sjt!
                  I'm happy happy.
                  I was wondering testing some transistors why they don't give the full information as in the manual. Also I was wondering respecting the accuracy why would one buy an expensive multi meter these days with these devices that are so more versatile.
                  Anyway thanks again guys.
                  It seems I will be a regular user in here I have plenty of projects and also if by any chance is there is something on Spanish that you need translating I'm your gal .
                  What I mean is that I want to repay the favor
                  Going to try to upload the firmware now... will let you know
                  UPDATE
                  Code:
                  C:\Program Files (x86)\Arduino\hardware\tools\avr\bin>avrdude -C ../etc/avrdude.
                  avrdude: AVR device initialized and ready to accept instructions
                  Reading | ################################################## | 100% 0.04s
                  avrdude: Device signature = 0x1e9307
                  avrdude: NOTE: "flash" memory has been specified, an erase cycle will be perform
                  ed
                       To disable this feature, specify the -D option.
                  avrdude: erasing chip
                  avrdude: reading input file "usbasp-2011.hex"
                  avrdude: input file usbasp-2011.hex auto detected as Intel Hex
                  avrdude: writing flash (4700 bytes):
                  Writing | ################################################## | 100% 7.28s
                  avrdude: 4700 bytes of flash written
                  avrdude: verifying flash memory against usbasp-2011.hex:
                  avrdude: load data flash data from input file usbasp-2011.hex:
                  avrdude: input file usbasp-2011.hex contains 4700 bytes
                  avrdude: reading on-chip flash data:
                  Reading | ################################################## | 100% 3.92s
                  avrdude: verifying ...
                  avrdude: 4700 bytes of flash verified
                  avrdude: safemode: Fuses OK (H:FF, E:C9, L:EF)
                  It seems it worked!!!
                  I have to test it going to reprogram the other one too and after test with blink with usb tiny I will let you guys know
                  Thanks again
                  Belen
                    fuses look wrong.
                    avrdude -C ../etc/avrdude.conf -c avrisp -P COM6 -b 19200 -p m8 -U hfuse:w:0xc9:m
                      Hi again
                      I did not have luck with my USBASP.
                      I used the arduino IDE to upload blink to ATTiny configureing the proper pin
                      Board: Attiny
                      Processor: Attiny85
                      Clock: Either internal 1 Mhz or Intrnal 8 Mhz (tryed both)
                      Programmer USBASP
                      I tryed to upload the sketch using prgrammer
                      Code:
                      Sketch uses 826 bytes (10%) of program storage space. Maximum is 8,192 bytes.
                      Global variables use 9 bytes (1%) of dynamic memory, leaving 503 bytes for local variables. Maximum is 512 bytes.
                           this check.
                      My USBASP is not recognized anymore
                      I did upload scketches to my attiny before with it. Before I messed up I mean.
                      Belen
                        I'm sorry I did not saw the other msg how can I check the fuses by myself what should they say?
                        I reprogrammed with your line code and it gave me this:
                        Code:
                        avrdude: reading input file "0xc9"
                        avrdude: writing hfuse (1 bytes):
                        Writing | ################################################## | 100% 0.03s
                        avrdude: 1 bytes of hfuse written
                        avrdude: verifying hfuse memory against 0xc9:
                        avrdude: load data hfuse data from input file 0xc9:
                        avrdude: input file 0xc9 contains 1 bytes
                        avrdude: reading on-chip hfuse data:
                        Reading | ################################################## | 100% 0.01s
                        avrdude: 1 bytes of hfuse verified
                        avrdude: safemode: Fuses OK (H:FF, E:C9, L:FF)
                        After this tried to upload the sketch again no luck same error as before
                        Belen
                          stj whilst waiting for parts to arrive i thought i would install avrdude ive tried it on windows vista windows 7 and windows 10 cant get any to install do any versions run on windows the usb programmers installed fine
                            Dear Vince sorry to step in
                            avrdude you do by commands you extract in a folder and do a command prompt in that folder to be able to type commands.
                            I believe for windows you got WinAVR wich is a GUI for ARVdude I might be wrong
                            Belen
                              there is something fucked about that AVRdude - it's not reading the correct fuses.
                              can you type "avrdude -v" to get the version.
                                Belen
                                WinAVR is not for programming, it's for making the software.
                                if you want a gui for avrdude, try avrdudess
                                http://blog.zakkemble.co.uk/avrdudes...i-for-avrdude/
                                and i found this.
                                http://ladyada.net/learn/avr/avrdude.html
                                  and i found this.
                                  thanks stj the top link has installed fine so just reading up on how too use it
                                    Belen
                                    Thanks bmht ive downloaded the one in stj links and seems too work ok its a pity avrdude wont work in windows cmd prompts i did try then realised wasnt for windows computers AVRDUDESS seems too work so just waiting o a smd ic and a header to arrive then will try it out.
                                    just to confirm that these blue lcd pcbs work fine with the old testers
                                    http://www.ebay.co.uk/itm/1711744250...%3AMEBIDX%3AIT
                                    two little mods needed though on the main tester pcb it has two 6 pin headers which then go to the screen pcb but on the old screen pcb one header has 6 pins and the other uses just 4
                                    on the new screen pcb i had to add two 6 pin headers as the missing two pins are for the backlight voltage and then a little tweak of the contrast variable pot sorted the screen out it looks good now.
                                      Code:
                                      C:\Program Files (x86)\Arduino\hardware\tools\avr\bin>avrdude -v
                                      avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
                                           Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                                           Copyright (c) 2007-2009 Joerg Wunsch
                                           System wide configuration file is "C:\Program Files (x86)\Arduino\hardw
                                      are\tools\avr\bin\avrdude.conf"
                                      avrdude: syntax error at C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\a
                                      vrdude.conf:999
                                      Downloading now V 6.3 and redoing the whole procedure will report back
                                      I also downloaded AVRDUDESS and I like it! It seems to be the same but with a GUI that for me really helps
                                      Thanks again
                                      Belen
                                        I like AVR DUDESS
                                        Code:
                                        -c arduino -p m8 -P COM6 -b 19200 -U flash:w:"C:\ASP\usbasp-2011.hex":i -U lfuse:w:0xef:m -U hfuse:w:0xc9:m:m
                                        and I got
                                        Code:
                                        vvrdude.exe: AVR device initialized and ready to accept instructions
                                        avrdude.exe: Device signature = 0x1e9307 (probably m8)
                                        avrdude.exe: NOTE: "flash" memory has been specified, an erase cycle will be performed
                                        avrdude.exe: erasing chip
                                        avrdude.exe: reading input file "C:\ASP\usbasp-2011.hex"
                                        #avrdude.exe: writing flash (4700 bytes):
                                        Writing | ################################################# | 100% 6.65s
                                        iavrdude.exe: 4700 bytes of flash written
                                        avrdude.exe: verifying flash memory against C:\ASP\usbasp-2011.hex:
                                        avrdude.exe: load data flash data from input file C:\ASP\usbasp-2011.hex:
                                        avrdude.exe: input file C:\ASP\usbasp-2011.hex contains 4700 bytes
                                        avrdude.exe: reading on-chip flash data:
                                        Reading | ################################################## | 100% 3.33s
                                         avrdude.exe: verifying ...
                                        avrdude.exe: 4700 bytes of flash verified
                                        avrdude.exe: reading input file "0xef"
                                        avrdude.exe: writing lfuse (1 bytes):
                                        Writing | ################################################## | 100% 0.01s
                                        avrdude.exe: 1 bytes of lfuse written
                                        avrdude.exe: verifying lfuse memory against 0xef:
                                        avrdude.exe: load data lfuse data from input file 0xef:
                                        avrdude.exe: input file 0xef contains 1 bytes
                                        avrdude.exe: reading on-chip lfuse data:
                                        avrdude.exe: 1 bytes of lfuse verified
                                        avrdude.exe: reading input file "0xc9"
                                        avrdude.exe: writing hfuse (1 bytes):
                                        avrdude.exe: 1 bytes of hfuse written
                                        avrdude.exe: verifying hfuse memory against 0xc9:
                                        avrdude.exe: load data hfuse data from input file 0xc9:
                                        avrdude.exe: input file 0xc9 contains 1 bytes
                                        avrdude.exe: reading on-chip hfuse data:
                                        avrdude.exe: 1 bytes of hfuse verified
                                        avrdude.exe done. Thank you.
                                          I have managed to get avrdude running in windows i forgot to make a new folder in c drive then unzip it there etc it opens in cmd ok now.
                                          so now have avrdudess and the normal avrdude on computer.
