Hi all. Given this 2011 model the Sanyo logo comes up at start and that is all but does have sound. Power board output voltages all check OK. Nothing obvious seen. To me the screen output other than picture does seem ok but menus etc do not display. Main is 569KI0601B no maker name and LCD is Samsung. Anyone with experience these models? Pics to follow.
Sanyo LCD40XR11F sound no picture -mainboard?
Re: Sanyo LCD40XR11F sound no picture -mainboard?
I think you may be right that they don't as I can't see any light from rear view (none of the usual holes) and its sus that no menu comes up. There is 24v output from power board. Will take cover off and see what I can on screen output boards.
Took cover off inverter and this revealed two holes thru which I can see that backlight comes on for a second then off. I understand board can have an overload protection circuit switch which can be bypassed for testing for a few minutes but will give that a miss. Inverter is SS1400_08A01 rev 0.2 and a lot of these available around $20/30 from overseas.
Yes I am punting on the inverter as ccfl beyond my scope - no indication of arcing seen or heard. This set is one of nine acquired in the past week. My work tools consist of mm , soldering iron, set of screwdrivers and very limited space - hobbyist only.
Around this time each local council has a household cleanup collection for old white goods furniture etc so I advertise on local Facebook site to take away non working TVs of 40" or more with unbroken screen. Very good response and a real mixture. Have got 3 working so far (mainly bad caps on power boards) and on track, I hope, with another 3 awaiting parts which will take around 3/4 weeks, and a lg plasma bad ysus working on now. Either keeping me out of, or getting me into!, mischief.
So far I have had best luck posting for free pick up of nonworking tv on Craigslist. But about 80% are cracked screens. Still I've gotten some good ones. Posted on facebook but not much luck.I assume no responsibility for any stupid suggestions I might post.
I think one reason for my good response is that in this yearly cleanup the sets just go into a compactor truck and become landfill. A number of people would rather give them to someone who may save them from that. Normally if they go to the tip they are passed on to a recycler.
After some weeks received new inverter board (and it does indeed look new) which went well but after about 15 mins picture jumped around sound went out of synch then all settled down but with about half inch strip of red colour across bottom of screen. Looks a bit like a foldover. Now after many weeks pulled set apart again to check t-con but where is it?? On main board or locked in screen frame?? See pics
The blank main board PCB can be stuffed with difference parts to create a bunch of PCBAs for the required TV models.
That LCD panel had integrated T-CON/Tab bonding boardsNever stop learning
