I have an ASUS VH222H. When plugged in there is no activity on the power LED. It doesn't light up at all. Because the monitor doesn't turn on, well, there is nothing on the screen. None of the capacitors are blown. I'm not really sure what needs to be fixed on the Power Board now. Any ideas?
ASUS VH222H No Power, No bad caps
Re: ASUS VH222H No Power, No bad caps
Originally posted by burns154 View PostI have an ASUS VH222H. When plugged in there is no activity on the power LED. It doesn't light up at all. Because the monitor doesn't turn on, well, there is nothing on the screen. None of the capacitors are blown. I'm not really sure what needs to be fixed on the Power Board now. Any ideas?
1. Disconnect the cable running to the signal card.
2. Fasten the power supply in place temporarily with at least two screws, one of which is through the grounding clip I circled in black.
3. Plug in the AC power cord.
4. Set your DMM to the 1000V DC scale and measure the voltage across the pins of the large cap (circled in red). Report that voltage.
5. If the voltage measured above is about 1.4 x line voltage, the fuse is good.
6. Set your DMM to the 20 VDC range and measure the voltage on each pin of the output connector. Use the mounting screw circled in black as the ground point. Report those voltages
If you read 5V on any of the pins of the output connector attach a picture of the signal card to your next post.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Originally posted by burns154 View PostAlright. I had plugged the monitor in like he said with the 2 screws. The power board started to spark. Should I still test, or could I get shocked or something?
