Found this great site a few days ago so just testing the water with my first posting, hoping someone out there may be able to help me…
I have a Cibox C1905 TFT LCD Monitor Model No. LW1922C which is giving me grief. It appears to be suffering from the ‘two seconds to black' problem.
When I was given this monitor it would work but turn itself off after a minute or two. I changed a couple of electrolytics which were showing signs of distress, my capacitance meter confirming their value had decreased considerably. This however has not affected a cure and the time the monitor will stay on has progressively shortened.
The on/off light is always on, turning green when the monitor ‘sees' an input. It stays green even when the picture goes off. Removing the source signal the on/off light turns amber but immediately goes green when the source is reconnected. The monitor then produces a picture for a very short while then goes off. Likewise switching the monitor off and on brings the picture back but quickly goes off again.
I seem to be able to see faint images with a torch when the screen is off.
Chyenne had a problem (not the same problem as mine) with a similar monitor and posted some pictures which I have gratefully borrowed (thank you Cheyenne):-
https://www.badcaps.net/forum/attach...8&d=1320597822
https://www.badcaps.net/forum/attach...9&d=1320597822
I do not have an ESR meter so cannot measure the ESR of the electrolytics. I do have a couple of DVM's and a capacitance meter. I always feel happier using an analogue meter to check diodes etc and I have ordered an analogue meter off eBay.
I'd be grateful for any help.
Incidentally I found a great ‘how to' on fault finding on flat screens, sure it was on this site but I can't for the life of me find it now…
Thanks.
Thanks.
