Dell 3008wfp faulty power supply
    Re: Dell 3008wfp faulty power supply
    Ok - test it again out of circuit.
      and how do I do that? Sorry for my noob-i-ness D:
        I think this will be a double diode so if it has three legs
        do the following test on one side and the middle then do it on the other pair ( middle and other side)
        This test is from retiredcaps 2 sec to black guide which is interesting for anyone doing anything like this- start at post 20
        7.3) Bad Diode
        Diodes (D or ZD designation) can be bad. To test a diode in circuit,
        a) put your multimeter in diode test mode
        b) put your black lead on one side and the red lead on the other - record reading
        c) reverse the leads - recording reading
        A good diode should read 0.4V to 0.7V in one direction and 0L in the other. If you get a reading in both directions
          Do I not need to hook up some kind of current to the diode for the test to work?
            NO! You only ever need power on if someone asks you to test/check a voltage.
              Your multimeter when set to diode test mode provides a small current through the diode. See
              http://www.allaboutcircuits.com/vol_3/chpt_3/2.html
              --- begin sig file ---
              --- end sig file ---
                Greetings,
                Count me too in the success stories list: last week the display died (completely: no blue/orange led).
                Found D22 died in closed circuit state, today I replaced it with a STPS60170CT and now it's back working flawlessly. It costed me about 3€ and 2 hours of work.
                Thank you all for this great thread.
                  Originally posted by phroid View Post
                  Greetings,
                  Excellent! Great to hear! Now if we can get fuus fixed up; I'll be able to sleep again
                    SO:
                    Original D22 Readings:
                    Black Left, Red Centre: 007, Black Left, Red Right: 007
                    Red Left, Black Centre: 007, Red Left, Black Right: 007
                    Replaced D22 Readings:
                    Black Left, Red Centre: 1, Black Left, Red Right: 1
                    Red Left, Black Centre: 122, Red Left, Black Right: 1
                    Original D19 Readings: (potentially shorted one)
                    Red Left, Black Centre: 052, Red Left, Black Right: 1
                    I applaud your commitment to helping people Lumberjack, I'm sure many people are grateful for the help!
                      You seem to have not done the test correctly?
                      First pair
                      Second pair
                      Black Centre, Red Right:
                      Red Centre, Black Right:
                      Where you have 1 do you mean 1 or Off Scale
                        By 1 I assume it means off the scale, as it shows 1 when the probes arn't touching anything!
                        First pair (D22 Original (broken!))
                        Black Left, Red Centre:020
                        Red Left, Black Centre:020
                        Second pair
                        Black Centre, Red Right:030
                        Red Centre, Black Right:020
                        First pair (D22 Replacement)
                        Black Left, Red Centre:1
                        Red Left, Black Centre:150
                        Second pair
                        Black Centre, Red Right:150
                        Red Centre, Black Right:1
                        First pair (D19 (The shorted one))
                        Red Left, Black Centre:070
                        Second pair
                        Black Centre, Red Right:070
                          bump!
                            [[[[[RETEST]]]]]]
                            Black Left, Red Centre:000
                            Red Left, Black Centre:000
                            Second pair
                            Black Centre, Red Right:000
                            Red Centre, Black Right:000
                            Red Left, Black Centre:115
                            Second pair
                            Black Centre, Red Right:115
                            Red Left, Black Centre:045
                            Second pair
                            Black Centre, Red Right:044
                              "First pair (D22 Replacement)
                              Second pair
                              Red Centre, Black Right:1"
                              Are you using the meter in Diode testing mode or using Ohm mode?
                              "115" is that MOhm, KOhms, Ohm, V?
                                Second pair
                                Diode testing mode. The multimeter is a 'Blackspur DT-100'. I have no idea about Ohms for the mode sorry
                                  When you check semiconductor device for short, use Ohm function since bad semiconductor junction will act more like low Ohm resistor, it will no longer act like Diode any more.
                                  D22 is OK.
                                  Check D19 in Ohm mode to see what you get, so far it looks like it has very low Vf.
                                    which probes on which side? and at what ohm setting? I have: 200, 2000, 20k, 200k, 2000k
                                    on the 200 setting I got a reading of 69.9 for red left and black centre
                                    I also got 69.9 for black centre red right!
                                      I just want to thank the major contributors to this thread - I'm in the same predicament and have got quite a lot to go on thanks to the posts here. Have ordered a pack of STPS60170CTs (minimum order of 5 :/) and will hopefully be taking a look at it this weekend. It's quite promising how many people have fixed the issue by changing this single component.
                                        "on the 200 setting I got a reading of 69.9 for red left and black centre
                                        I also got 69.9 for black centre red right!"
                                        Now do the reverse:
                                        black left and red center
                                        black right and red center
                                          both get no reading what so ever.
