I have a plasma TV set that I am having some intermittent problems. Its occasionally powering off and not restarting until the TV sits for a while.
It was recapped with Panasonic FC/FM's that did not solve the problems and have a separate post that has more details:
https://www.badcaps.net/forum/showth...382#post729382
Im now inspecting the PS board and have attached some photos below that show some of the more suspicious solder joints. None of the joints seem at all loose or not solid. Im not sure if a cold or ringed solder joint could be the source of the intermittent problems Im seeing.
In the images below there are two fets where the vertical cuts are in the board. The FET on the right seems to have some ringing on the left most pin that looks suspicious.
The FET on the left center pin seems to have had some rosin crusted and a somewhat hazy shell.
Would greatly appreciate any help in interpreting the images of the joints.
Im planning to replacing the remaining large high voltage caps and retouch the solder joints but with the intermittent nature of the problem it is hard to tell if I got the problem.
Appreciate any feedback or tips.
Kuma
Kuma
