Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > All Others Motherboards
Thread Tools Display Modes
Old 12-23-2016, 03:37 PM   #1
alindumitru46
City & State: Craiova
My Country: Romania
I'm a: Knowledge Seeker
Default ASRock K7S41 issue
I have that board for few years ago. She died suddenly and there was not a way to revive.
That evening I found it in a box by chance, looking for a replacement mobo for someone.
Thanks to the knowledge gained here on the forum, I immediately found the cause: VRM Q4 was dead.
I noticed that the two areas in figure remained united after vrm desolder. Is there a risk if the two zones are united? I tried to clean the area, but my soldering iron is pretty skinny.
VRM Q5 is 70L02H, what is best equivalent that I can use?
Thanks.
alindumitru46 is offline   Reply With Quote
Old 12-23-2016, 10:47 PM   #2
ChaosLegionnaire
HC Overclocker
City & State: Singapore
My Country: Singapore
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist Tech
Default Re: ASRock K7S41 issue
i think that could be just the body pad for the mosfet to dissipate its heat through the pcb. if in doubt, just use a good branded low wattage psu with known working short circuit protection just in case...
ChaosLegionnaire is offline   Reply With Quote
Old 12-24-2016, 03:24 AM   #3
alindumitru46
My Country: Romania
I would have tried anyway, but I thought to ask before doing fireworks before Christmas
There could not be a big loss: a weak Duron CPU, some RAM, in the worst case and a PSU
The only thing that keeps me on hold is the equivalent for 70L02H .
Old 12-24-2016, 10:34 PM   #4
ChaosLegionnaire
HC Overclocker
not sure how to check if its a short when the solder is bridged together. im still quite nub on component level repair.
but what u can do i think is to put the multimeter in diode test/continuity mode and put one probe on the solder pad and the other probe on the positive leg of a cap on the vrm high or low side depending on whether that mosfet is a high or low mosfet.
then put the probe that was on the positive leg onto the negative leg of the cap and see if u get continuity on one or both legs with the mosfet solder pad. if both legs get continuity, the positive and negative side of the circuit may be shorted together so u must use a wick, solder sucker or whatever to get rid of the solder bridge.
if u get continuity to only one leg of the cap, it should be fine and shouldnt cause fireworks on power on, i hope...
Old 12-24-2016, 11:50 PM   #5
alindumitru46
My Country: Romania
Bravo, young man, you're shrewd. Eventually it was logical that, but for now I have not bothered, because I do not have the component to replace.
Anyway have you spared me for an extra work
Thanks.
Old 03-19-2017, 02:31 AM   #6
alindumitru46
My Country: Romania
3 months later...
I found an AP85T03GH as replacement for 70L02H:
http://alltransistors.com/mosfet/crs...009&caps=TO252
I checked before replacement and after the origial mosfet Q3 70L02H and the replacement AP85T03GH : both has ~600mohm trough Gate and Drain but both fail the continuity test after soldering.
I really don't know...
Old 03-19-2017, 05:23 PM   #7
cpt.charlie
City & State: Torrelavega
My Country: Spain
Line Voltage: 230VAC 50Hz
Maybe your problem is related to the VRM controller, remove the mosfet and test it out of circuit.
cpt.charlie is offline   Reply With Quote
Old 03-20-2017, 09:45 AM   #8
alindumitru46
My Country: Romania
Vrm controller is the ST L6910 ADJUSTABLE STEP DOWN CONTROLLER
WITH SYNCHRONOUS RECTIFICATION with 16pins, between LPT port and 462 CPU socket?
Must verify the pinout voltages after power on?
I said already about the test of the both vrm: Q3 and Q4 out of the circuit and after solder...
Old 03-20-2017, 04:19 PM   #9
cpt.charlie
My Country: Spain
That seem to be the VRM controller, what a crappy board! socket A boards used to have 3 phase VRM modules. if you have a shorted phase your board won't start at all.
BTW, in your photo there are 2 black caps near the northbigde that looks bloated, check them.
Old 03-21-2017, 04:09 AM   #10
alindumitru46
My Country: Romania
I used the last two pictures from internet because have better resolution, so the capacitors are ok .
I'll check in the next weekend.
Thanks anyway.
Old 03-25-2017, 03:30 AM   #11
alindumitru46
My Country: Romania
My BIG mistake!
The VRM controller is not L6910 but ST L6916D!
And I cannot find datasheet.
Old 03-25-2017, 11:23 AM   #12
cpt.charlie
My Country: Spain
This is all i can find.
File Type: jpg 20090120_3a8fbd3d1525ec1ee4c8HjLrgTri14F3.jpg (39.3 KB, 3 views)
Old 03-25-2017, 01:42 PM   #13
alindumitru46
My Country: Romania
There is a solution for a similar issue with a different mobo - ASRock P4V88.
The solution seems to be too complex - osciloscope needing?!:
https://translate.googleusercontent....GEnOHO6N-U_ETw
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2017
Powered by vBulletin ®
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
