Here we go,
Ive tried reading and done some trouble shooting already but, this unit powers up for three seconds then flickers to black. I also heard a hissing sound coming from one of the inverters, upon further inspection the molex plugs are melting when powered up(see photo's).
I've not checked any power feeds yet as I don't wanna power it up till the inverter problem is fixed. But it does have power to the control button board(blue lights), I do get a display for a few seconds at first then blank.
Things I have done:
I tried only hooking up one set of inverter plugs at a time to see if it was one bad one, same result from both.
The small caps on the main power board looked bulged on top(see photo) I replaced them with the exact same caps, when I replaced them it seemed as if someone else had already soldered new ones in place? The old ones are in these photo's and circled in red ink. There are five medium sized caps circled in white ink, I replaced them already not sure if I used the right type(low ESR caps). The caps circled in Yellow seemed OK they are ELITE caps.
Pretty much this is where I stand at present, when it does first power up it has a full display and shows the Acer sign then blank. Before I replaced the caps, it would only power on for like one second then blank. I noticed when I got the display one of the corners of the casing seemed white-ish. As if something may have struck it, or maybe dropped on its corner as normally its black.
Things I have done:
