X93W lcd problem
    Re: X93W lcd problem
    ok, that answer my question, the lamps are independant, not connected in serial mode
    ok, I will connect one lamp at a time from the x93w to the good lcd and see
    thanks
    btw: I have ordered too quickliy the board.... never mind that was not so expensive
    18€
      You can either sell it on though not sure how many machines it will fit
      OR contact the seller and ask how much to cancel - should be ebay relisting fee?
      plus a bit for his trouble.
      You should save a bit on postage.
        Some update
        I have connected the lamps from one to the other, one by one, two by two
        and I went back to the original lcd, which was faulty, but now it is working.....
        I saw a little damage on one wired, due to the fact I moved the wire the problem went away....
        I will do some test tomorrow
        thanks for your messages
        Yves67
          You may be able to resolder the wire - there is a post somewhere on here
          saying how to do it- I will look tomorrow or perhaps other members will chip in while we sleep.
            This may help:
            http://lcdparts.net/howto/troublesho...topSCCFL1.aspx
            I have done many lamp assemblies repair but I am not good at explaining how to do it exactly.
              q
                The problem is fixed, I think it was the wires which were a little damaged
                putting them differently it is working
                thanks to all of you
                have a good day
                yves67
