Hello guys,
I have another 2 seconds to black problem I could really use some help troubleshooting.
The monitor in question is a samsung 2243swx, which is a series I had never heard of before and it belongs to my boss (apparently I am becoming well known around the office as the monitor repair guy now). He brought the monitor to me and I confirmed the 2 seconds to black issue. One of my first tests was to connect a set of known good CCFLs, one of them lights completely right away, the other one starts with about 10mm of very dim light and extends out to about 25-30mm within the 0.5-1 seconds it takes for the protection circuit to kick in and the inverters to shut down. After a few seconds it tries again and this time it can light 50-70mm of the one set of CCFLs (the other set still lights perfectly) before it shuts down.
The caps on the board are "SAM YOUNG" brand, and none of them are bulged however I have not yet built an ESR meter to test their ESR. I will try swapping them today for new ones but I do not expect it to fix the problem at this point.
I checked the resistance on the secondary coils of the transformer and got the following:
Good side: 891
Bad side: 961
If I test them after trying to get the board to light CCFL's for 10-15 minutes the numbers are closer together
Good side: 928
Bad side: 958
The transformer is labelled TM-0815 and from what I can tell the secondary side should have a resistance of 875 ohms (as determined from one product page, so maybe this is not trustworthy information).
I thought perhaps it was a set of bad capacitors on the high voltage side so I swapped the caps from one side to the other, there was no change in which side would not light.
I also desoldered the transformer to check it for burning (as the board looked darkened near it) and found no evidence that it has been overheated.
I measured the resistance between all sets of pins on the 2 ICs on the bottom side of the board and found no shorts.
Am I looking at a bad transformer here? What else could it be? The monitor belongs to my boss and he is willing to pay the ~$26 for a replacement power board but I feel like it should be possible to fix the problem with this one. I hate to buy a transformer on a guess, but I already have a spare one of these coming (as I bought a pair):
http://www.ebay.ca/itm/250773133702?...84.m1439.l2649
Can I replace the transformer with one of these, then connect it to smaller CCFL's (as this transformer is only rated 650V instead of the 700V the board for the 2243swx specifies) to rule out whether the transformer is at fault???
Thanks for any input you guys can provide!
Good side: 891
Bad side: 961
Good side: 928
Bad side: 958
