Syncmaster 244T
    Syncmaster 244T
    I was given this monitor from a friend because the screen was all green or something when plugged in through component. I wont be using component and the image is just fine with VGA. The problem is a loud hum or buzzing noise that I have tracked down to the transformer. Is it possible to order a new one? There is also a rattling noise when I move the other pcb board. I have no idea where it is coming from or if its a problem but it sounds like a round ball inside one the capacitors perhaps. Any idea what this can be?
    Image 78 has the transformer on the right and 81 has the rattling.
    Thanks for any help
    Re: Syncmaster 244T
    There are at least three failed capacitors on the power board.
      Re: Syncmaster 244T
      And the rattling is from the position sensor on the signal board. The signal board was designed to be used in a monitor that can be rotated from landscape orientation to portrait orientation.
      PlainBill
        Re: Syncmaster 244T
        jsog- i counted 3 as well but ordered replacements for all of them.
        PlainBill- That's pretty clever. I am glad it is not an issue.
        Any idea where i can find a new transformer? Are transformers generic or specific to every case?
          Re: Syncmaster 244T
          Virtually every SMPS transformer is designed for that specific power supply. Quite often a manufacturer will use the same inverter transformer on several different models.
          First replace the bad caps. They allow excessive ripple which can cause damage, particularly in the inverter and corrupt eeproms on the signal card. If the buzzing is still an issue the usual solution is to saturate it with varnish.
          PlainBill
            Re: Syncmaster 244T
            I really appreciate you sharing your knowledge PlainBill. I will update when I replace the caps.
              Re: Syncmaster 244T
              I replaced all the caps and so far so good. The annoying buzz is gone! Thanks a lot everyone.
