Hello, I'm having an issue determining the value for a 5-band resistor on my LG 42PJ350-ub power supply. The bands in order are: Orange, Blue, Silver, Gold, Black. Tested out of circuit returned .6 ohms. To my knowledge this color combination should not be valid; and I'm hoping someone more knowledgeable than myself may be able to decipher this code.
TV resistor not making any sense
Re: TV resistor not making any sense
What resistance do you get when you touch your meter probes together? about 0.3 Ohms, then that is correct 0.36 Ohms + 0.3 Ohms for the meter lead. This resistor when it failed, it will usually go open circuit.Never stop learning
is looks more like inductor to me http://cdn.instructables.com/FRQ/J6V...NQFK.LARGE.gif
It's a 0.36 5% wirewound-resistor.
The marking color "BLACK" means manufacture's series .
Some for Nonflame type with BLACK marking ; or
non inductive wire wound resistors(無感繞線電阻) ---> GREEN
inductive wire wound resistors(有感繞線電阻) ----> BLACKAttached FilesLast edited by Duncanbest; 12-04-2013, 09:57 AM.
This resistor is probably for the Source pin of the MOSFET or fusible resistor for the B+.Never stop learning
