Re: All Over White Washed Out Picture LG 42LF2510
I re-seated the Tcon cables and the weird ghosting and darker area went away.
Interesting a bad connection on a Tcon cable could cause such a weird effect on screen
So I still have the very fine vertical lines. There is cyan one which sometimes goes black if you push gently against the right T-con cable and sometimes will disappear all together
There is a yellow one very close to the cyan one which does not want to go away.
I tried swapping the two Tcon cables but it makes no difference to the location or intermittent nature of the lines.
Do I have another faulty panel? This is so annoying after I fixed the AS15 fault, I could get the intermittent blue/black line before the repair but as it would go away with a touch on the Tcon cable I thought it was a bad connection and that seems to be the case.
The yellow line was probably there all the time but I could not see it due to the original fault
Anything else I can do with this?
Rich
Rich
