I have HP 2009m monitor that is suffering from the 2 seconds to black problem. A couple of times it has stayed on a bit longer but it hasn't done that for awhile.
I went ahead and changed all the Elite caps except for the very large one. I haven't changed the four rubycon capacitors (top center).
So far I've found that Q901 (P10NK70ZFP) is showing 3 - 102 ohms for a couple of seconds but only with black on pin 2 and red on pin 3. I'm not sure if that means it's bad or this is the way it's supposed to be. I've attached the datasheet for it, hopefully someone with more knowledge can let me know.
Thank you for any help and advice. I hope the picture quality is okay, my camera doesn't seem to want to do close ups.
Thank you again!
Thank you again!
