Hi, so my problem started with my Samsung 2493hm screen going going black and the blue LED blinking. So i searched around and figured it must be the power supply. I ended up replacing all the caps (None looked swollen). I also replaced the db804 diode since there were burnt marks around it and it was cracked in the middle.
So now the screen still doesn't turn on, but the LED is solid blue. (Which i figured meant that the power supply is ok). But when i measure the outgoing voltage (in picture 3), where the voltage should be 5.3V it is only reads 0.44V. But the pin that says "S_B" reads 5.19 and the "PSOM" reads 3.17. And the outgoing voltage (in picture 7) should be 24V but I don't get any reading.
So i included pictures and my multimeter and hopefully someone can help me.
I can provide more pictures and reading if needed. Thanks
