First I'd like to say, what a great site! I am the kind of person that hates it when a favourite piece of electronics dies, leaving no option but to toss it in the trash...what a waste.
I'm hoping that "bad caps" is the answer to my recent problem with my Samsung 305T monitor. I've had it about 4 years now, and about a year ago I had the common flickering problem. That has since been fixed by modifying the signal board with heat sinks and a small fan. All has been good until a couple days ago when the monitor was coming back on from power saver mode. The screen came on for a split second and then went off again, on-off, on-off, continuously. The on-off continued for about 10sec and then the monitor came on and stayed on, remaining on for several hours. Then later that day the monitor started doing again from the on condition and never stopped flashing on-off so I switched it off. Turning the monitor off and on did not fix the problem. I did notice that the area around the power supply board was very hot, almost too hot to touch. After reading online about bad caps on the power supply board I disassembled the monitor and inspected the the PS board. I found a variety of Rubycon and CapXon capacitors, but none show signs of bulging.
Does my problem sound like bad caps? Do I not see any bulging because the caps are only just starting to fail? Any advice would be greatly appreciated.
Best Regards,
Jim Thompson
Best Regards,
Jim Thompson
