I got Windows 95 OSR2 installed and running happily on my IBM PC110 (this thing MUST be the smallest laptop ever built) and now I want to top off the functionality by adding wireless to it.
I have an Orinoco silver card which has been reflashed to gold using modified firmware and now I'm installing the driver/software/utility.
Now the installer for all of the above is stored in a zip file and for reasons inknown, to get it to properly install you need to use the "check out" option in WinZip.
As I reached the end of the installation I'm told...
...which essentially means that I need winsock2 to be installed so I download it and install it and then proceed to configure the card to connect to my router and it seems no matter what button I click in the utility, the result is always the same:
...or in semi-rare cases...
I thought it meant the install botched but I uninstalled and reinstalled and got the same error.
I then also tried installing a different version of the utility but it still crashes with the same error.
The readme says this is for 95 and not 98 (where I have never had problems with the utility) but why would it be doing this?
Code:
$HOME$ requires the correct version of comctl32.dll. Run the file w95ws2.exe from the folder \xtras\windows on the CD-ROM Alternatiively, consult to the Microsoft website for the correct update.
Code:
An error has occured while Windows was working with the Control Panel file C:\windows\system\WNLUC41.CPL
Code:
ILLEGAL OPERATION CMLUC caused an invalid page fault in module COMCTL32.DLL at blah blah blah
