No 5V found in this Circuit, Please help me.
Re: No 5V found in this Circuit, Please help me.
Originally posted by nazrul145 View PostI uses 80k resistor and result same. When i put adapter power up laptop and shutdown after 2-3 second.
I do not understand.
You've changed the resistor to pin 4 on 278k and put 80k resistor and the result is the same?
yes same. also pin 4 have 5 so that 3.3v not going to coil.
when i remove pin2 resistor 3.3v ok when remove pin4 resistor 5v ok. but when use this two resistor only 5v continue present, but 3v come when adapter pluged in and turn off 2-3 second. that means 5v continue ok but 3v problem.
Originally posted by Compute View PostIn the datasheet says that the 2-pin and 4-pin stand at 100k resistors, try to put it to 100k for 2-pin and 4-pin
Just try to put resistors on 100k, not 80k, 100k is, it's not difficult, way to pin 2 and 4 should be a low level
