This unite has black screen can see desktop with bright light but back lights are not starting. The ccfl are tested ok with another board. Caps have been replaced. Voltage checks reveal 165 dcv across the large cap o volts at all points to the logic board. 56 volts dc at both ends of the start resistor? I read a post somewhere by PlainBill that the voltage at the start resistor should read 170volts one end and 10-25 volts at the other end so is this a indication that this resistor is bad and can someone tell me the value of this resistor? This one is covered with heat shrink and I can't read it without taking it out.
Sorry this unite does not power on, no led. My bad but was thinking of another unite however all other info is as posted
