Samsung 226BW
    Re: Samsung 226BW
    Thanks again
    No, I hear nothing like what you mention:
    "noise between the On and then OFF , like a hiss, or a red/pink hue in the screen?"
    Nope.
      Re: Samsung 226BW
      Originally posted by RATTLERMAN View Post
      EGuevarae
      Thank you for reading!
      My screen does the same things as it did before I replaced all the caps as described in this thread.
      When connected to [power] and a video source, I see blue surround light at power button in the bezel, and all online images on the LCD, EVERYTHING, for about 2 seconds, and then it goes black.
      I can also hit the [MENU] button and see the MENU for a brief time, but this does not repeat.
      I am not sure if I do that before replacing the caps.
      I see the [analog/digital] display upper left for a few seconds, then black.
      This also does not repeat, unless I power down, and up again.
      Thanks again!
      No sound or pink hue?
      If you connect it to a video signal, you should be able to see the screen (dimmed) when the lamps go out by using a flashlight. If you can't, besides the inverter/backlights we have another problem.
      I was checking my notes and I had changed lots (lots...) of lamps on that model because one dies...I assume you don't have another unit to use the lamps to test, right?
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • Windows 10 Pro x64
      • GeForce GT1050
        Re: Samsung 226BW
        Here are the spec sheet numbers on the Beckman:
        That meter is just fine.
        Looks like a pretty good one in fact.
        Do put in a fresh battery if it's been sitting so the readings aren't off.
        I'm more of a motherboard guy and EGuevarae is more of a screen guy so since you are past the caps change I'm going to let EGuevarae take the lead and I'll just sort of lurk and play side-kick.
        Mann-Made Global Warming.
        - Dr Seuss
          Re: Samsung 226BW
          Hello EGuevarae
          Yes, the image is normal for about 2 seconds, and after that I can see it very dimly using a flashlight.
          I have a small Sony model SDM-X52 that works fine.
          Could I test with that one?
          Thanks!
          Another thing.
          I think that the dim backround image was a little easier to see before I replaced all the caps.
          I think that I could just barely see light and dark areas without using the flashlight.
          Now I need the flashlight for sure.
