I have a Samsung 52" TV that has multicolor vertical lines on the right side about 1/2" wide. As the set runs the lines disappear until only 1 green line remains. Occasionally another line will appear but will go away by touching the screen at the tip of the line. Do you have any ideas about the problem or how to fix it?
Samsung LN5265FX/XAA -VERTICAL LINES
Re: Samsung LN5265FX/XAA -VERTICAL LINES
You can attempt to use thermal pads to press the ribbon connections, 'Sometimes' you may have success but it is a tricky thing to do.
Otherwise there is nothing else that can be done, When a panel dies that is the end of its life, It may or may not get worse
