What is causing this?!?!
Pink bands
Re: Pink bands
Ok new observations. Now when i pull up adjustement menu and turn down cell and turn it back up it stops but when it switches to another commercial with brright back gound it starts. Already tried vs adjustements and reseated ribbon cables on on each side of screen and t-con. Its like it resets. This also affects the menu.Main board? t-con? power supply? y sus? x sus?
Re: Pink bands
Aged/old/worn plasma-panel.
Sometimes you can cover it up by increasing the Vs about 5-10v, but the prob will return in time.TELEFIX
Re: Pink bands
As Alastair says. Try to increase the Vs voltage. You need to measure it so you wont inmediately go 20V up.
The potmeters are on the Ysus board , maybe a little tweak on the Zsus board also helps. Last one helpt me on a old panasonic plasma. White was more green , i turned up the Zsus and it was gone.I only repair Panasonic plasma tv's! Currently owning a TX-P55VT50 and still searching for a ZT60!
Re: Pink bands
Originally posted by hotcoffee View Postafter 3 yearrs?
Ive seen many a Samsung with a dodgy PDP, and Always the Newer ones, while the old duffers go on forever!TELEFIX
